You would have to do the belts if you take the crank out as the belt runs of the bottom pulley which is bolted to the crank!
my mechanic said number 3 shell a piece had come off and blocked off the entrance for the oil so it run dry.he showed me the piece that blocked the oil off il get a pic put on here for you to see.
i would be happy to use the crank again providing the journals have been mic'd up and checked for size.
