Engine mount cost
Car  Evo 6, E92 320d
Looking to replace my engine mount and the one under the battery(think its the upper gearbox mount), its a 1.6 16v engine, how much are the parts from renault?
The top engine mount is £68 from memory and the upper gearbox is only around £20. I think the part numbers are the same for the 172, whats your cars code and fabrication code?
The engine code is K4M, when i looked at them both they were pretty much identical to the 172.
Are all of those 1's the same fitment on the 1.6 as the 2.0 or only the upper mounts?
Part numbers im getting are
gearbox upper 8200089697
enginer upper 7700434370
Im sure the upper is the same on all clio IIs, or at least it looks the same. Need you vehicle type e.g. BBOA and fabrication number e.g. k006626 to be sure.
The numbers I gave above are correct for your car, looks like all Clio IIs use the same upper mounts bar the 1.2 8v.
