clio sport 172
I've been getting the dreaded knock under hard
acceleration , So I bit the bullet and bought a
couple of engine mounts O/S Front by the cam
belts. And the gearbox plug under the battery
O/S easy peasy gearbox plug not so easy.As
when I try and undo the centre bolt through to
the box all that happens is the mount twists to
the point where I think the mount will split rather
than crack the nut. Any one had a similar problem
or advice.
Cheers Colin......
or advice.
Cheers Colin......
