Engine mount !
Car  Clio 172 Flame Red
right , was driving yesterday and started getting alot of vibrtions from the engine and knocking when pulling off , i think it could be the engine mounts not sure which one not had a chance to have a proper look but engine looks to be sitting quite far back in the bay ??
tried moving the engine back and forth by grabbing the inletmanifold ? MAY be one of the top ones has broken if it cam upe all of a sudden ...
yea theres quite alot of play when moving back and forth !! is that the top mount ??
the one on the left you can see; the one on the right is under the battery.. SOME play is normal, say 2cm (1cm back, 1cm forth) by hand
There's also the dogbone underneath the car and all mounts wear quite easily/fast on these cars , but as yours seems to have come up suddenly i'm thinking one of the top ones because they are known to even snap (under battery especially)
hmmm i dont have time check all mounts atm but will get on it 2moz and check it out , bloody french Sh**Box !
just went out in it only seems to make horrible vibrations in foward gears not reverse ?? any help ?? maybe the driveshaft ?
