Engine mounts - what to buy???
I would like to know if the K-tec mounts cause any extra vibration and harshness. I am planning on driving my Clio out to the Ring alot and cant be doing with nasty vibrating mounts!
Fred,
Do you recommend the poweflex for the dog as it gets the most abuse?
Would the dogbone bush be the usual candidate for something bashing the bottom the car under hard upshifts or when first gera traction skips?
Regards
Andy
You are such a superstar you are Fred!
THANKS.... AGAIN!
is this advice still the same with ITBS as well?
what about Gearbox mounts? use standard as well?
Will get all engine and gearbox mounts replaced with new standard Renault ones as car has done 60k miles now. (puls the powerflex dog bone)
good option?
yer the power flex dog bone stopped the nocking on mine under hard acceleration in 1st and 2nd. Fred fitted :)
The powerflex'd dogbone still increases vibration throughout the car but it reduces, not stops, the vibration from the manifold under harsh acceleration, from my experience.
I'm going all singing all dancing uprated mounts all throughout. :)
Might I also add that the OEM dogbone bush is weak as s**t. Mine went after just 30 minutes of tracktime.
Powerflex one has so far lasted just fine throughout a full trackday + the usual abuse it gets day to day.
Danny - how can you tell if the Vibratechnics mounts are fitted properly? lol
You changed all your mounts mate? :)
got the powerflex and the vibratechnics fitted today. initial impressions are more vibration at idle (not excessive) and smoother through gearchanges and on and off throttle.
also seems to have quietened to exhaust a bit as it too :)
No....not yet.
Just saying I will be doing despite a previous comment recommending not to.
I've only powerflex'd the dogbone mount atm.
i think i'm sold on the powerflex dogbone bushes. does the 172 cup have the inline or the twisted dogbone?
do the oem mounts have to be bought from renault themselves?
I've bought them from gsf and euro before. The dogbone one was EXACTLY the same - had the same markings on and was half the price, that was from euro. Had a top mount from gsf and that was fine and half the renault price.
hmmm, just seen on yozza sport they do a kit which consists of:
1. Dogbone Mount2. Offside Strut Top Mount
3. Front Subframe Mount
4. Battery Tray Mount
but i don't know if the subframe mount and battery tray mount have bushes/ are prone to failure
The subframe mount is more of a support and does not usually wear out. It is the upper engine and gearbox mount which cause most engine movement.
David.
some sites say the dogbone is the lower gearbox mount, but ktec racing list a lower gearbox mount @ £17, so i don't think this is the dogbone
No the front lower gearbox mount. The dog bone mount is under the back of the engine between the engine and gearbox.
David.
ok, i plan to replace the dogbone bushes with powerflex ones.
working on the assumption that fitting powerflex bushes will cause the next weakest bush to fail, i should replace
lower gearbox mount
upper engine mount
is it wise to replace the upper gearbox mount?
i think that's all the bushes.
The most popular course of action is dog bone mount, upper engine and gearbox mounts (usually uprated versions) and then a standard lower gearbox mount.
David.
