its dripping from the bottom of the car, where the oil is emptied i think, i think there is something missing.. got my car out today since a while then theres a huge patch of oil, and i drove it today and where every the car is stationary theres a patch of oil of where it was. basically its leaking oil from the bottom of the engine. i just want to kno what needs to be placed on it to stop it from leaking so i can order the parts
new sump plug then. check the sump for damage.
or even around the engine for oil leaks
If its leaking from the sump its the waher you need to change so drop the oil and use a new sump washer. Some places are to cheap and don't use a new one and it means it leaks.
Just check it tight though I've known ones which have been resued sump washers to come loose
cheers mate il check it through tomoro.. god iv had enough now iv only had this car a week and everythings wrong with it
