20VT Clio & 9-5 HOT
alright folks, bit of a long one this, but tells the whole story, so i hope someone can give me some help or guidance!
some of u may remember me having idle problems and stalling at junctions etc. (i made a few posts about it, and i know many people have had the same problem)
well the initial problem was very occasionally, and all i had to do was pull over, let it idle for 30 secs and it would sort itself out and then be fine for weeks.
very occasionally the car wouldnt start. only happended on 2 occasions. a bump start started it, and it sounded rough as fuk for about 1 minute or so, then sort itself out and be ok, bar the dreaded cutting out and idling problem. on the last occasion of this, the car never became normal again, and i had the low idle and cutting out problem at all times
Well here is what i did!
changed the fuel filter.
changed the iscv. was ok for a while then back to usual.
also changed the speedo cable and road speed sensor, still the same.
then changed the potentiometer (from another valver, untouched)
changed the throttle body
changed the iscv (again), after this lot it was much better, after starting the car at first it idled at about 2krpm for a while then sorted itself out and was running spot on for the first 30mins drive, but then started to struggle at idle again, and the revs dropped low still at junctions, but not always to the point that made it cut out.
next i chaged the lambda, still the same.
then changed the cooland temp sensor and timing sensor, seemed much better on idle but after a drive it was the same again.
next changed the ecu for a mk1 clio 16v one instead of a 19 16v one, and also changed the map sensor, and upped the fuel pressure a bit.
now when i start the car from cold, it sounds rough as fuk, when it initially starts it doesnt rev up a little as normal (for like 1 second), it just starts and doesnt go above 700-800rpm sounding terrible (rally sl*g style ), but after a bit of constant gas up to 3.5krpm (about 10 secs worth) it seems much smoother, but still the revs drop really low after letting off the gas. this is before iv set off!
So after the engine sounds much better, and i drive it, the revs are dropping nicely to about 1200rpm and then slowly to about 900 as it should. no sign of cutting out or dropping revs at all.
once the engines warmed and i start to rev it a bit more over 4krpm the revs then dont drop anymore than about 1400rpm, and it idles at that until the engine is turned off and on again, when it then idles ok at 900rpm.
so in conclusion its much much better, but at first start its sounding rough as fuk, like its runnin on 3 cylinders, then its running ok, but after some gas above 4k revs when driving the revs then dont drop below 1400rpm even at idle
told u it was an essay lol! but just givin the whole story as im really wanting to get this sorted.
since i had the cams in and the engine rebuilt, it was running mint for months, although the cams were never timed, fuelling wasnt setup, and it wasnt chipped (although running mint, and quick as owt). since the rebuild the engine is very lumpy on idle though!
do you think this may be part of the reason? i was thinking of maybe taking it to renault! bit pricey tho, and im only a poor student!
Cheers for any help!
