Engine problems
Hi,
Ive got a 2000 1.4S clio.
Recently whenever you go to drive off, the engine struggles/has a dip in power just as you pull off.
Now todaywhenever the car was running it would shake/vibrate when silent.
And when driving home i felt the power loosing power, cutting in/out.
When i pulled into the drive there was a serious amount of white smoke, and looking under the bonnet theres alot of fluid/oil under where the coolant tank is and all around the drive shaft below it.
Theres also some fluid/oil under where the oil filter is, but the oil level is fine, hasnt changed.
Another thing whenever i was in neutral the car would have moved forward slowly as if the clutch wasnt disengaging.
Any ideas?
