engine rebuild bottom end and turbo info needed
Car  clio 172
HI ALL
Right i stripped my engine for rebuild as its high mialage, anyhow lucky i did all the bores were scored not great ahahaha so i went looking for another f4r block. so i found a block and brought it with 60k on it i gets it home to find there are more than one f4r block ahahah im thick annnnyyyy waaaayyy i have ended up with a scenic 9.8:1 compression bottom end and was considering using it for a turbo conversion as it lowers the compression from 11:1 im not sure on the boost to run and what sort of bhp i will be getting also i have been port matching so just need some info on the boost and anything to do with tht so i can start to bolt the old girl together.
oh none of the valves were seated properly soo well needed the rebuild.
thanks phil
