Hi All,
Thought I'd let everyone know what I'm doing with the Clio track-day car. I've met a load of you at track-days over the past year or so, and shown my stripped + lightened Clio 172 Cup.
I'm yet to get the car weighed properly but it's completely stripped and running full polycarbs, fibreglass panels, and fibreglass doors.
Aside from the exhaust, the current engine is relatively standard. To keep the car on the track, I've bought another spare engine from a fellow CS'er. It had low compression, but as I plan on doing a LOT to it I don't think it will matter. I'm in the process of taking it down to bits now before I do the following-
No doubt you will have seen this thread, I'm following it quite closely: http://www.cliosport.net/forum/showthread.php?523216-260bhp-tonne-Clio
This is the engine that I got, which apparently "runs" just very badly - not bad for 40 quid (!)
And now, step one, get the block bored and ready for painting, and for that we need pistons...
I think I found the source of the low compression whilst I was taking the head off - the rocker was smashed to bits and the collet on the top of the valve was nowhere to be seen. I suspect that it was the pistons that were lifting the valves back up!
Anyway, plenty more to come, and will update this thread as I go! Thanks for reading, Rhys.
- Send block off to be bored and honed, going for 84mm oversize pistons with 12.8:1 (approx 2066cc)
- Send head off to be ported, polished, angle seats cut, cleaned up, etc.
- Order Catcams 423's with appropriate valve springs, considering VVT delete
- Order appropriate forged con-rods, bearings, and bolts
- Order throttle body kit (120mm trumpets, 48mm bodies)
- Order remaining rebuild items where appropriate
