Post a pic up of your crank mate and I’ll be able to tell you how likely it is to happen.@NorthloopCup thank you very much. Knew I seen it before, but couldn't find it at all when I needed it.
Only thing that worries is I've heard these engine can have dramas with spinning the 3rd bearing and I'm also hoping when I measure the crank end float the thrust washers I can use are standard size.
The design more than anything mate.nothing to do with the oilway drilling by any chance?
Will do mate when I get the time looli g at starting the rebuild within the next month as currently in romania with work.Post a pic up of your crank mate and I’ll be able to tell you how likely it is to happen.
No problem for a decent machinist.how hard would it be to have the block and tods tanged?
@NorthloopCup crwnk measured with a micrometer and all within tolerances. No deep scoring or pitting anyway, just a few dull shiny marks on the surface. I'm going to get it nicely polished up. Any pros to running King Bearings for a standard build? Probably get some cams and port matched inlets but that about it. Or is it best to stick a set on oe renault bearings in.Post a pic up of your crank mate and I’ll be able to tell you how likely it is to happen.
King bearings have larger tolerances iirc as they’re more race biased, so you’re better off with standard bearings. Also, that crank is one of the ones that will potentially spin a centre main. All luck of the draw though I’m afraid.@NorthloopCup crwnk measured with a micrometer and all within tolerances. No deep scoring or pitting anyway, just a few dull shiny marks on the surface. I'm going to get it nicely polished up. Any pros to running King Bearings for a standard build? Probably get some cams and port matched inlets but that about it. Or is it best to stick a set on oe renault bearings in.
@NorthloopCup how do you work that one out mate? Is it due to the oil holes in the crank? Surely the best way would be to get tanged and better bearings? Or just try my luck with OE Bearings.King bearings have larger tolerances iirc as they’re more race biased, so you’re better off with standard bearings. Also, that crank is one of the ones that will potentially spin a centre main. All luck of the draw though I’m afraid.
It’s due to the lack of counterbalance weights on the crank mate.@NorthloopCup how do you work that one out mate? Is it due to the oil holes in the crank? Surely the best way would be to get tanged and better bearings? Or just try my luck with OE Bearings.
So the 'good' crank is the 197 one right?It’s due to the lack of counterbalance weights on the crank mate.
If it’s going to spin, the tags on the block/rods won’t stop it. The crank flexes due to the poor design.
Trust me mate, I’ve been around these engines now for quite some time, so I know their downfalls.
So the ph1 crank is the best crank. Then the 197, and followed by the 182 crank. The ph2 172 crank is still rubbish.So the 'good' crank is the 197 one right?
Thanks!, I'll get it right someday....So the ph1 crank is the best crank. Then the 197, and followed by the 182 crank. The ph2 172 crank is still rubbish.
The best blocks are the ones that have seen some heat cycles. Then they need checking for straightness of bores and journals, and machining if they’re out.Thanks!, I'll get it right someday....
Any such difference in blocks?
