ok cheers guys i changed my spark plugs about 2 weeks ago engine sounds really noisy down to the shudder just to add i had 16 new valves timingbelt head skimmed done about 5/6 week ago due to pretensioner collapsing and i have now got a whine in first and second gear also when revs are dropping back it just seams really lumpy also i seem to have a buzz from my throttle body
ok cheers matebuzz from throttle body may be the normal noise it makes. It does make a high pitched noise.
hi no i dont have a decatJust to add, do you have a Decat?
no wev not checked that yetHave you checked all the wiring? I know the garage that did mine said it was bad earth on the ECU and the ECU contacts, could be worth a try
will do mateMine has this problem to let me know if you get it sorted please buddy
im based in colne lancashire mate like da saysWhere about's are you based fella? Mine did this and it turned out to be the wiring
lol ok will do mate and will check the ecu connections aswell iv not checked the lambda sensors but iv had my toxic fume warning light on a few times comes on then goes off :SSo many people so close lol, try the wires under the fusebox, they often corrode, and check the ECU connections etc, you checked the Lambda sensors?
were are you located mate is there any chance you can come and have a look for me as im crap at the whole car thing lolSo many people so close lol, try the wires under the fusebox, they often corrode, and check the ECU connections etc, you checked the Lambda sensors?
It could well be a Lambda then, it it's not reading right it'll mess with the fuelling and could cause it to overfuel, giving bad performance and then the backfire, I live in foulridge, but am currently in Leeds for uni exams. When I'm back I'll give you a shout, I have a spare Lambda or can try mine to see if it sorts it
ok thanx mate cheersMy car will cut out sometimes when i start it if i dont give it a little rev, its not happened when warm though! Also in cold weather will give a pop or 2 from the exhaust. And finally i got the whine sound from 1st and 2nd gear at low speeds :rasp:
Sounds just like mine to be honest mate! But never gives any problems once on the road, i think most are like this matey but unsure. Just thought i'd mention that i have the same sort of things happening
yeah true i dont know if my sensors are coverd under warranty tho or its wear ect im not going to even touch the sensors untill iv spoken to perrys to see what they sayThe car is still under warranty though so bear that in mind before you start messing with sensors etc.
Personally I'd have it back to Perrys and explain to them you're not happy. As I said to you yesterday, if it was my car I'd be dumping it back with them and not wanting it returned until it was 100%.
