Engine Stutterer at 3000RPM-Clio mk2 99
Car  Clio 172 RS ph1
Hi,
i replaced the 2 heating hose after one of them was leaking, and i needed to buy the whole 3 hoses, they came as a set.
probably some sensor got wet after i opened the old heating hoses.
the Sputter is happening in every gear after i reach 3000 rpm.
if you keep the foot on throttle its Stuttering until i leave the pedal.
on idle its not happening.
any ideas ?
Thank a lot !
Daniel.
Forgot to update, solve it out, the crank sensor had coolant fluid between contacts, I cleaned it out and dry, and its perfect for 3 months now.
