Yep that the fluid.Terrorist said:Type D, is that the day glow green stuff? I already have a spare 5ltrs of that in the garage.
What tools will I need?
I have socket sets, spanners sets, screwdrivers
Is there anything special needed?
Cheers Edde
Oh and I have a haynes manual GavFre, but there is usually a much quicker way or a better order of doing things etc
Nope with the subframes off the engine etc all drop out downwards.Terrorist said:Cheers Matt.
Do i need to split gearbox & engine if dropping out the bottom?
Remove all hoses, remove all cables/wires, undo engine mounts, remove driveshafts, undo subframe = Engine drops out?
stan* said:ball joint splitter yes.
32mm socket for driveshaft hub-nuts.
stan* said:lol u jew!!
does that answer the question?!
Terrorist said:My collant (proper green renault shizzle) has only been in for sub 100miles (changed it when I fitted my samco's), will it be ok to reuse it for one of the cars? or is that just being tight? lol
matbrown said:You sure your not a Northerner??![]()
Mat.
