Engine swap
  172
1.4 Lump coming out.
http://img444.imageshack.us/img444/9637/img3459vh3.jpg
Getting the ECU out
Anyone fancy a good used 2nd hand radiator? :D
Donor Valver - raped.
Aaeron (ronsvalver), working on the valver lump, the water pump, cambelt and clutch were all changed.
Much bigger than the 1.4 in comparison.
Aux belt off, cambelt being tensioned.
Radiator off the valver going in.
[/img]
Dropping the valver in, this was difficult, mainly because it was so big and secondly the front panel wasn't removable so there was very little room to work in, the subframe had to be dropped on the passenger side to get the gearbox in right.
Just got about in, and seated on it's mounts. Then we fitted the downpipe and lambda and exhaust.
Fitting the valver loom, this was also difficult as it didn't just plug and play like intended, instead we can to fabricate another loom where it interconnects with the 1.4 loom. The valver ECU was also chipped with a limit of 7500 instead of 6250.
Immobiliser wires causing grief.
Brakes (R21t), driveshafts, shocks and springs on from the valver.
Bleeding the brakes, used the master cylinder off the valver - used a lot of parts off the valver, it was only £60 as well.
Trying to fit the aux clocks off the valver but the loom was slightly different for the 1.4 so need them from a 94+ valver, mine was a 91.
Finished product.
This thing is great fun coming from the 1.4, the insurance just means that it goes to grp 12 which is fine (Adrian Flux). The power compared to the 1.4 is much better, it pulls hard right up to 7k RPM, not taken it to the limiter yet. The only problems it was having was a high idle which was suspected to be the ISCV.
However my fun has been cruelly cut short due to the head gasket going. We didn't change it while the engine was out (wish we had now) and that is going to cost £400+ great. This was suspect as soon as the engine was going, as the water was boiling even though engine temps were fine, ahh well, live and learn.
I think it's definitely worth the cost though as it's a fun little car now, fast enough for me at the moment too. Just a shame about the HG (got a payen one to go on, but i cba to do the work). So yeah big thanks to Aaeron as he did most of the work and traveled quite far to help out every day for a week!
guid work mate, must have taken a fair bit of time!
scottish plates on your car i see :approve:
