ESP button on a FF 182?
Darren S
What's the deal with these then? I presume its something you can switch on and off? Nothing changes on the dash lights when I press the button.
Maybe mine's broken? ;)
D.
Sounds like you've got a bulb out matey.
It turns the ESP on and off. Little triangle with a skidding car should come on the dash when its off.
Or a faulty switch, I know people had problems with the cruise/speed limiter ones breaking.
I'd go with faulty switch as the clock use LEDs and its not very likely that ones failed. Does happen though.
don't worry too much though.... as if you want it off it needs to be pressed every time you start the car.... otherwise it automatically reverts to being on...
