Disclaimer : Please bear in mind I have never changed an exhaust so sorry if this entire post is retarded.
Got a prospeed cat-back system off a member on here (thanks dave
) and attempting to fit it on sunday. My car is a 1.6 16v (K4M)
Now, i've got 2 clamps and none of them seem to fit properly. Although one does fit better than the other. One is a cheap U-clamp and the other is what eurocarparts told me was 'the correct clamp for a cat-center section join on your car, not a cheapy clamp!'
But I have since discovered I need 2 clamps. One from cat>center section and one from center section>back box
The two clamps I have can be seen here:
The (cheaper) U clamp is 51mm and the other clamp has '58' stamped inside it...
This is how the more expensive clamp fits. Is it meant to be like this? I thought it was meant to hug the shape of the pipe all the way round? (i.e without the gaps around the outside?).
This is how the U clamp (51mm) fits. In a nutshell.. it doesnt! Tried everything apart from deforming it to get it to fit over the pipe.
Any ideas guys? Does anyone know which type and which size I require? Thanks!
