exhaust issues
Car  182 and cherokee 4.0
i have a k-tec ultra performance exhaust on my 182 and i can't for the life of me get the thing to sit level and central. i have changed the mounts and had revolution try and sort it to no avail. is the problem likely to be that the exhaust tips are off centre or not aligned properly? if so, is this something that can be altered?
also, i have it lowered on sportlines and had 3 people in the back and was parking on a high kerb and something bottomed out on the car (i believe it was the exhaust). it made an awful squeeling noise. it then bottomed out again when i abandoned parking on the street and tried to pull it onto the drive. i didn't think the car was that low, guess my passengers are fatter than i had thought. is this likely to have done any damage or loosened anything?
cheers :S:)
Try AAS over in Newcastle not sure if they will mess around with it but their own exhausts are second to none, maybe worth a shot.
cheers, i will have to try and get under and have a proper look. hope it's not like
just had a look and it's defo blowing from where the de-cat pipe joins the rest of the exhaust. will i be able to get this repaired you think???
am i likely to need a new exhaust or de-cat or do you think i might be able to just tighten it back up?
