Exhaust Wistle under load 2-3k
Car  RB FF 182
Evening folks,
I've done a search and it didnt really turn up what I was after
Had this problem for a while, and its starting to bug me.
When speeding up gradually or aggressivly once the car hits about 2.2-3k theres a hissing noise from the passneger foot well. Somedays its worse than others. Sounds like a blow out at a gasket or similar.
I ahve replaced the compression ring [ i think thats what its called ] between the CAT and the rest of the exhaust, but this didnt cure it either.
I have a KTec Ultra performance cat back on at the moment, but i'm unsure if it done it before this as the old exhaust was so loud.
I had it in at a Powerflow dealership that i work near and they were useless tbh, didnt even try to look at it really.
The best way to describe the noise is like an old passat/vag derv comming onto boost. Really is rather annoying.
Performance isnt effected as far as I see as it acheived 183.9 on the rollers not so long ago.
Any help much appreciated.
Could it be more of a high pitched rattle Niall? My heatshield had me looking for airleaks a while back and thats what it was.
Have you the acoustic valve still attached, its down that direction of the car
I had a noise from about the same area. Turned out to be the join between the cat and center setion. Half a tube of high temp silicon and a new clamp solved it. Clamp was about £6 from Renualt.
The man is correct!
New exhaust peice from center section to my newly fitted decat new clamp and a bit of exhaust paste now theres no more noise! Yay!
