Update,
Fmic fitted, k03 turbo, fabricated manifold, cat under car, all pipework and sensors done also,
Just back from Wales yesterday evening, spent weekend at new road garage,  We did new clutch, gearbox oil changed, new spark plugs, mocal oil cooler mounted next to fmic but not able to plumb in as the wrong size oil feed pipe was sent, need a standard Clio one to finish this off but it's there in waiting, sparco 300 steering wheel with quick realise boss, carbon fibre evo 7 bonnet vent and front toe strap was fitted. couldn't find room to fit catch tank anywhere
The boost control valve be fitted Friday at ktec so they can adjust boost when they Map it, they will also fit the 182 injectors.
Car already has 20 25 mm spacers, lowered 40mm. Looking to raise bonnet to help get rid of heat from turbo too, not massively, just enough to allow air to escape.
From gosport to south Wales and back, 38.5 mpg, and 1/4 tank left over.... Now on 50.5 mpg around town, 0.5 bar boost,
