Falling Tyre Pressure
  Was a Clio 1.8 16v
When i had my old phase 2 wheels on, one front one seemed to fall down to 25psi every week whereas the other front tyre maintained 35psi. Theres no offending object and their new tyres on front. The same happens with the rears.
Just bad tyres? Or wheels have erroded and no longer has a perfect air tight fit to the rim? If this is the case does re-fubbing them sort out the seal edges?
Could be leaky valves mate. I had a front tyre that kept losing pressure (very slowly). So, I took it up to my local garage and they just replaced the valve. It literally took 2 minutes. Problem solved!
Exs has a feck off great big screw in one of the fronts.
Its typical - non repairable, over 6mm of tread left AND its an Eagle F1 thats about £55 to replace!
Argh! :)
  Was a Clio 1.8 16v
Not likely to be a corroded edge inside rim then?
That was the reason behind my last slow puncture, but they were steal wheels, and this pressure loss is slower than that. Nearly new Falkon tyres on the wheels at mo?
  clio 20v
my ph 2 rims did that it was leaking from the edge of the rim took it qwik fit an they cleaned the edge an put a load of sealer on it an it was okay
adi
  Was a Clio 1.8 16v
Thats what i reckon mines doin, but i thought you had to replace them when that started happening?
What kind of sealer? Cheers.
