any persony who is suffering from clio cobra alarm problems 9/10 its the siren under the drivers side scuttle panel, sometimes this is unaccessable or mabe you are just not confident to do the work but either way the wiper blades need to come off to fix it
the clios wipers a VERY prone to get seized and can cause the windscreen to crack during removal therefore i have devised a small guide to disarm the alarm compleatly from the alarm module
firstly use the guide to remove the dash on fubars site in the guide section and then you will be left with this
after removing the dash there is 6 of the same screws in the air bag unit passenger side remove it and wobble the airbag out and hold it or as in the pic get a friend to hold it while you take a snap![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
this should show the cobra alarm module.... if you intend to fix the system later then pull the fuse as i have or remove it as you wish
i rang loads of places a pulled a lot of favors to find the location and eventually got to it but dont be fooled absoloutly none of the main dealers knew where it was they all wanted to remobe the scuttle panel to pull a fuse which i new even the frogs wouldnt put a fuse in the engine bay....
any way pleasure to write this guide
job done
PS after market alarms will fit here and the wireing in 99% universal
:rasp:
![](/proxy.php?image=http%3A%2F%2Fimg510.imageshack.us%2Fimg510%2F9029%2Fdsc00504kl2.jpg&hash=f0b1b77989ece352401972833485958c)
![](/proxy.php?image=http%3A%2F%2Fimg510.imageshack.us%2Fimg510%2F9029%2Fdsc00504kl2.d8bab1eadb.jpg&hash=0f61c310ce3291290d3d2efcac31948a)
![](/proxy.php?image=http%3A%2F%2Fimg210.imageshack.us%2Fimg210%2F2162%2Fdsc00505fx5.jpg&hash=1e9b3d1949c313bdbb27a37135dd30b8)
![](/proxy.php?image=http%3A%2F%2Fimg510.imageshack.us%2Fimg510%2F6354%2Fdsc00506td9.jpg&hash=303fe5ed29c470f075ea7b6b1b411ded)
![](/proxy.php?image=http%3A%2F%2Fimg210.imageshack.us%2Fimg210%2F5227%2Fdsc00507rc3.jpg&hash=a5c08b0783f65a524234367bd92af2f4)
:rasp:
