FAO those with Bilstein B14 Coilovers
Anybody who has this setup on their car, have any of you removed the rear adjusters? Any problems come from it?
Would like to get the rear of mine to sit a little lower, but I don't want to be having a "spirited" drive and have the rear springs fall out on me over a bump!
  Lionel Richie
should be fine, i've noticed that on all the ones i've done the rear needs that little bit more (especially on stripped cars)
Gaz_
  Extreme mode
I've left mine as it is, set up for go rather than show ;)
Even goes on the Birchdown lift with no help, which apparently is a massive fail.
  Lionel Richie
^are yours in the right way up? i swear i saw a picture of a cup with bilsteins at Birchdown with bilsteins fitted with the rears upside down
Gaz_
  Extreme mode
um?
Look right to me?
  Lionel Richie
adjuster is upside down mate, its supposed to go at the top ;)
doesn't matter though, it just says so in the instructions
if you put them in the way it says it becomes impossibe to adjust the ride height though - odd
Gaz_
  Extreme mode
Your not wrong!! How odd!!!
Gaz_
  Extreme mode
Yeah, i actually went and got the instructions out the box in the shed to check! Ah well, not fell off yet ;)
