few more random questions lol
Car  e92 + E46 M3 + Cup
First one thats been on my mind,
When using megs 83/80 combo can i lay something like EGP straight onto it or do i still have to put down a coat of SRP?
Also that megs cleanner wax stuff, can that have EGP put on it or will it not bond properly?
And finnaly if the weather ever givs into some sunshine i was going to treat the car to the full works -
Car washed / clayed / dryed then
Start with megs 80 on the g220 & decided if megs 83 is needed, either of the out comes i will finnish with megs 80
Then i will lay down some AG EGP providing i dont need to lay down some SRP as i have questioned above
Then finnish it all off with R222 :cool:
What do you guys think?
ive bee told by rich that wax or sealant wont bond well with 80 or 83. And should work some srp in after so i can seal and finally wax.
I'd use a Glaze then a your R222 on top of those.
EGP will only bond properly on top of SRP, so I'd steer clear of that.
I'd consider using a sealant other than the EGP, such as Jeffs or CG Blitz, which I'm really liking at the moment. Used it as a drying aid the other day just to see what it would be like.
I would use SRP to ensure the EGP bonds properly.
#80 leaves lots of polishing oils behind that the EGP won't bond to well.
