First MOT on a 182 Cup..what to check ?
Car  Peddled device
As above....is there anything that it may fail on that l should check for now? The car is just under 20k and runs A1.
Its just been into Reno for a suspension problem and they found the oxygen sensor needed to be replaced...maybe they checked it out and apart from that all was well.
Are there any issues with the rear brakes like the 172 Cup?
Doesn't matter, just get it MOT'd before the warranty is up.
182cup aint a proper cup so has ABS ;)
What was your suspension problem? Picked mine up tonight and theres a banging on the o/s/r strut when you hit a rough bit in the road.
Ive been given a warranty to make sure it goes through the MOT if i have to pay for anything its covered but i doubt you'd have a problem.
Just makes sure the bulbs are fine, theres no play in the wheels, seatbelts work ok etc etc its just common sense really
Yeah...two weeks to go so will book it in with the garage doing the works van on Trafford Park...maybe even get it done tomorrow.
If anythings wrong i'll be like the guy at the end of Independance Day...." Hello boys....l'm back ! "
