Gave it a quick go - It's bloody hard work - Removed some swirls, although not all which proved to me that you'd have to try pretty bloody hard to damage you paint with a PC!! Now I have had a go, I'm doing my missus's black Mk3 Clio next weekend - Will post the results.
Really pleased with the results, even on my Silver 172 - Used DACP on a Sonus yellow then Speed glaze on a white pad. Have no idea if that was the right way round, but my cars paint is as smooth as a babys arse.
I could only do the big panels though due to having no masking tape. I also found the pads I have too big for some parts -
Can you get smaller pads?
And what's the best masking tape to use - is normal stuff ok to stick on? I'm worried about having to spend hours picking off bits of tape!!
I have a 'finishing pad' too - What are the best/recommended LSP's to apply by mahine? I'm using P21s atm and really rate - It's so easy on/off that I can't see any reall advantage to applying it by machine!!
TIA
TIA
