I know i'm gonna get trashed for this, but have you considered ebc yellow?
I wanna see other's experience with these pads before I type my opinion on it.
I've only owned a Clio for 200 miles so can't offer specific advice for this platform, other that the DS1.11s on my car have incredible bite but are incredibly loud when warm.
As others have said, performance comes at a price in terms of dust and disc wear. There is no pad that offers better performance than DS2500 with comparably low dust. So it's a matter of working out how much dust and disc wear you are willing to tolerate, versus how much performance you want.
Ive been running XP10's since July last year.. Ive done about 10 full trackdays and about 300 road miles.. My car is a trailer queen and used as a trackcar only so i drive it pretty hard on track.. Im still on the same set of Brembo hc's that seen 7 previous trackdays, using 2 sets of PBS, previous to the XP10's going on.. The discs are still very usable and my Black TD 1.2s have not been harmed..I might have to give the RSL29 a shot. That’s a pad I’ve not tried - all of the others I’ve ever used which give me the stopping power I need have been corrosive particularly if driving in the wet. I haven’t used XP8, but XP10s are pretty bad on both discs and wheels.
Yea after the PBS only lasting 3 days, ive been pleasantly surprised with the XP10's longevity.. And id say theyre about half way dead.. After id killed the second set off PBS i was actually going to try Carbon lorraine CL6, but after hearing that they fall apart/crumble after wet use i went with Carbotech.. I will add that they are expensive at just over £200 but id definitely recommend them.. Ah you say Impreza.. Ive had 3 back in the day.. And tbf i also remember that the wheels would stain/mark quite irritatingly badly with just standard OE pads..I’ve not used XP10s on a Clio, only Imprezas. Really surprised to hear this feedback tbh as it’s totally different from my experience, but it’s good to hear. I got into the habit of cleaning my Impreza wheels after every drive. Also pretty encouraging that you can get 10 trackdays from a set of XP10s in a Clio!
My last Titanium 182 came with Mintex 1144’s on HC discs and I was really impressed with the performance - just a little noisy.
Hi GeorgeIt's hourses for courses with pads. like with most modifcations, what makes the car better on track, makes it a little less easy to live with as a daily
Sealing of wheels, and regularly cleaning helps with the dust. The noise is relative to what you're used to, I've run uprated pads for that long I don't really notice them
Personal preference comes into it of , a bit like with tyres in that respect. Some rate some, while other slate them
If you are planning to do plenty track days the endurance type pads like the RSL29 and DS1.11, do make sense as they wear well and are generally kind on discs. i supply a lot of the DS1.11 to track and front running race cars , and run them myself, I just really get on with them as they suit my driving style
better rear pads, do help scrub speed off, keep the car braking flatter , and will wear better as not at their upper temp limit (but cost more initially)
Compound wise, on a FWD hot hatch "text book" would be like below
front DS1.11 + rear DS2500
front M1155 + rear M1144
and so on
Can PM me for prices/info @frayz as you know mate
and so on
That’s the setup I’ve got on mine Mossy. I can’t speak for track but on the road they are fantastic. Sometimes a little squeal but mostly silent.
I've rarely ever had to do rear pads in any of my Clio's as they last so long but I done a pair of rear discs a few years back and stuck a set of pads in, at the time I was fully aware of the "just fit the std pads they don't do anything" and the only "uprated" pads I could find were EBC green stuff which, I had tried in the front of a car in the early 2000'sand they were average at best, but on the rear of the Clio the car felt great under breaking it felt more like I had adjusted towards a tad more rear bias. Possibly it was just that the old pads and discs were that fucked that a setup that does very little was doing even less but im going to try it on the van and see how it goes again.Thanks for all the superb responses guys. Out of interest, what are you running on the rear to go with your front pads of choice?
Perhaps you should try something with more bite. I’d say you’re missing out in free performance improvement there.god rear pads! I've never even considered changing them, buy the cheapest and thickest possible and never replace them.
Well you raise a good point there I probably should consider something different but the rear is so unbelievably light that the back almost does nothing, even more so when the weight is transferred to the front. I think on a more balance car like a saloon it would make a lot of difference. I definitely need more front brake and cooling now it's turbo though. The speeds it's trying to scrub off are pushing the limits of the current set up.Perhaps you should try something with more bite. I’d say you’re missing out in free performance improvement there.
I know when I went from having 360mm AP 6 pots on the Impreza on the front only with standard brembo rears to fitting 330mm 4 pot AP rears the difference was significant in terms of stability under braking. Yes that’s a bigger 4wd saloon, but the principals are the same.
Even more so now you’re running a turbocharged Motor.
This, and also because Fred said so in 2007 lolMy theory of the reason people have bought into the whole “the rear does nothing” idea is because with significantly improved braking up front and crap £15 quid pads in the back, the rear really is doing nothing.![]()
@frayz - So after this minefield of a thread have you got any further on thoughts for a fast road pad? After getting back into the Clio I've found my brakes just seem to lack that bit of bite even with fresh fluid.
I'm currently just running ECP Pagid pads for the road and have just ordered some TRW road pads due to some good feedback on this forum (I managed to get a set for £12 on eBay lol so thought why not).
M1144, M1155, mixed feedback and some reviews about squealing.
DS2500 - similar to the above really.
PBS ProTrack - no feedback at the moment but concerned they could be noisy.
Then you're going up the ladder toward serious track pads which I would rather avoid, as much as I like my DS1.11s and the bite is amazing, I cannot live with them on the road.
Funny you ask mate as i am waiting for them to be delivered. I have kind of chickened out and gone with what i know works and i like.
Ive gone back to Pagid and after numerous discussions it took me little time to decide on them as i just love them.
So opted for RSL29s up front and the RS2-2 for the rear. Not the cheapest route i could have taken but without question i know they will perform, last and not eat my paint.
Just as a bit of an exercise myself i put in my OEM road spec Brembos up front and some DS2500s in the rear just to see how much difference rear pads make. Now i've made no reservations for how much i dislike DS2500, but they are a undoubtedly a marked step on from stock in terms of friction and bite. The braking with them in the rear is quite noticeable as you actually feel the rear working quite well.
I just wanted to see for myself just how much of "nothing" goes on at the rear axle and my conclusion is actually quite a lot.
@frayz ive found the 1155 unreal on the road and track - trumps the ds2500 - I’ve had both. You do get some squeal from the 1155, but the bite they give more than makes up for that.
1155’a blew my mind how much more confidence I had in braking distances. When they’re up to temp, they were amazing. I’d get no fade from them even from 140mph stamps on the brakes. I’d get a hard peddle, but no fade.
I echo this response above. I used to run 1155 fronts and 1144 rears in my track car. Not once did i have any issues with them. The pedal and bite was always consistent, and the harder i pushed the better they got (this was lengthy periods out on track too)
I didn't think the cold response on them was bad either for road driving.
I can't recall them being massively dusty either compared to the DS range of Ferodo pads.
Infact, I'm seriously thinking about ditching the DS1.11 (having previously used 2500's and 3000's) and going back to them.
Was on my ST170 which had single piston calipers all around. Obviously a much heavier car too (1115kg without driver)Is that in the 197 though? It's a completely different experience with the single piston 172/182 setup.
If using Mintex 1144 pads on the front,for the rear its good to also use M1144's?.would this even things out than just having standard pagid pads on the rear?
Should be ok. If you think about it that’s what the car would have oem - same friction Front and rear, the brake bias sorts the rest
