depends on your polish? Do you put it on the car wet or dry? If dry just hose off the lube for left from the clay then dry it with chamoise or microfibre, if wet just wack it on after claying.
Wash, then depending on the weather, IE if it's cool and the water is not going to dry up on the paint, then you can strait to the clay, using QD spray (or soap and water mix) as you go along.
Wash again.
Dry.
Polish.
Wax.
Or, if you want to seal, you can do before the wax.
