Fitting a k-tec stealth
It can be done with the beam in situ, i've fitted my old stealth doing it this way.
But it's a LOT easier to drop the beam, when you consider it only takes two minutes!
easily done with the beam up matey, 10mins max. dropping the rear beam is just the two damper bolts. 18mm i think. undo them, jack under the beam, lower jack, beam drops down. sort exhaust, beam back up. done :)
Cheers for the help and advice.
Carn't fit the zorst because my center section is only 2" as to the 2.5" k-tec pipe:dapprove:
Need the center section
Happy to help.
M
best off just buying a centre section mate than chopping it up with reducers etc. for the hassle you'l go through youd be better off with it. you could also just cut your centre seciton out and make a straight through section thats what i did. is had a very sligtht bend in the centre section, only minor but a straight pipe works ok as thats what i have on mine and its fine 100% no problems!
