Fitting a radiator on a an 02’ Plate Clio Sport 172.
Hey all,
It seems my radiator could be leaking. Coolant level drops when I have filled it up and there is a drip from the bottom corner of the radiator when looking underneath at the front.
Been quoted £140 for a new radiator.
Question is how hard would it be to fit myself?? Would it be easier to get a garage to do it or could I attempt it on my drive?
Please don’t say it’s a bumper off jobbie etc.
Carlos
remove the slam pannel and they undertay and the fuel rail protector its pretty easy to change the Rad, you will need to remove the air-con parts etc but you dont need to remove the bumper, a new nissins rad will only cost you £70. it may not be the rad it may be the lower coolant pipe looking at the engine from the front its to the lower left have a look down there for leaks quite common
