Fitting a SUBWOOFER
1. You need to run a power cable from your battery to the boot.
2. You need to run a remote from the back or your head unit to the boot along with a set of rca leads. Probably best if you run them the opposite side of the car to the power but it hardly matters.
3. Fit amp to the back of the seat or somewhere appropriate. Connect to power and remote and then connect an earth lead to somewhere decent in the boot floor.
4. Connect the sub to the amp
5. Enjoy.
Any questions?
You have to run the wires so that they are apart from each outher, if you don't you will get interference.
Probably best to run the wires in the plastic trim aswell or under the carpet if you want to go to the extreme... Bolt the sub to the floor so its not going anywhere (none of the velcro shite)... To get the power cable to the battery you can push it through the bonnet release cable gromet in the passenger footwell. Might need a bit of drilling depending on the size of the cable.
Any other questions...... PM taylor :rasp:
Probably best to run the wires in the plastic trim aswell or under the carpet if you want to go to the extreme... Bolt the sub to the floor so its not going anywhere (none of the velcro s**te)... To get the power cable to the battery you can push it through the bonnet release cable gromet in the passenger footwell. Might need a bit of drilling depending on the size of the cable.
cool thanks for the help, isnt the earth near the battery of the car or is it in the boot?
can use an earth in the boot, where something bolts to the shell, needs to be a decent bolting point though, not just like a screw
It doesnt matter where u earth it as long as its on a metal surface. if ur gonna do it on the boot floor try sanding a small area down to the silver metal and then screw it in there thatll give a definate connection.
youll need a ring connector for the wire to the battry, if you buy a pre prepared kit it will come with it
I always hear people sayin this but iv had all my wires under the same trim for the past year and a half an never had any interfearence or problems.
yea its a full kit i got the amp sub and wiring kit with it so just need to get the thing fitted but im a f****ing goone when it comes to this stuff.
run the power cable down the drivers side through the grommit on the bulk head and onto the battery,
take the earth from under the carpet somewhere make sure you sand it so you get a good connection, then drill a hole and just use a self tapper to attach you're earth cable.
run the rca and blue remote wire down the passenger side door
then plug all that into you're amp and run speaker cable from the amp to the sub...job done
it's very very easy if you know what you're doing.
run the power cable down the drivers side ??through the grommit on the bulk head and onto the battery,
You must have been lucky. The correct way is as I & few others put.
so pritty much i gotta wire my battery wire down the passenger side n the other one down the drivers side to the head unit n just wire my earth cable in the boot right?
yup u got it right power wire thought bonnet grommet on passenger side all the way into boot.
remote cable and rca wires does drivers side
earth wire from boot to amp
then sub to amp
if its all done right the amp will light up saying it getting power and should go boom boom and to be honest on quite a few cars i have put subs in for people i have always ran wires down same side and never had a problem but as people have said it can course probs gd luck:D
then sub to amp
if its all done right the amp will light up saying it getting power and should go boom boom and to be honest on quite a few cars i have put subs in for people i have always ran wires down same side and never had a problem but as people have said it can course probs gd luck:D[/quote]
best advice so far man cheers, lets just see how it goes when i get it 2mora!! all im concerned about it conecting the power lead to the battery i take it you unscrew an exciting lead and place it over n replace it with the new one connected as well as the excisting one??
where you based mate, i can fit it for you mate, im in s.e. london, i fitted rob192's for him ages ago in the dark and took all of 10mins,
( when he brought my 2 12;s and amp,) how you doing rob?
He bought my amp aswell :S
