Fitting an amp on clio 182
Car  Focus RS, 182 gone
Hi,
Im about to fit my stereo into my 182, trouble is, i cant find anywhere to thread the live wire from the battery into the car. Can anyone tell me where it will thread through, without taking things apart to much?
Passenger side footwell, shove hand up behind sound deadening about halfway youll find a grommit. this will lead to the engine bay behind the sounds deadening that side. Better off removing the fluid bottle to the to it. Poke through with a wire hanger or screwdriver
I cant find it, unless its the one that has 2 wires already running through it? which is visible without going under the sound proofing?
Mate, iv just spent 30 mins tryin to poke a wire coat hanger through that grommet, it aint happening, its as tight as a ducks arse. No way the wire would fit through, is there an easyer option??
Quote: Originally posted by Sport182 on 27 May 2005
Wtf wheres the nice one Sport182 thanks for the guide LOL :p
Sssshhh ;)
You need two people to do it.
Eviljohn was braver than me and pushed his arm right behind the coolant bottle (which was removed) as i shoved the power cable through the grommit using a wire coathanger. Once you get hold of it, its easy.
Gotta give it some force!! Stab a screw driver through it!
Helps of you remove the coolant bottle then you can force your arm down the back of it.
