yeah,
remove the cat/decat,
remove the the small heat sheild directly under the gear stick,
under the 4 13mm nuts holding it on and the 13mm nut attaching the gear selector. then fit the new one
Have a look in the group buy section on the PMS short shifter thread. There is a photo instruction manual in that thread that will show you everything you need to know.
It's easy enough once the exhaust is out of the way. I managed to get it out just by dropping the exhaust a bit
