No point IMO the problem is your caliper iwll only clean a small outer section of the disk.Stu_c said:i wanna get the 325mm ones for mine![]()
Renault 19 from what I remember its not difficult to find though.Middo said:eddes cheekily found out what car takes that size disc, and i think its a renault 21 or 19... im sure he'll correct me though![]()
Arr right I thought you mean using stock calipers.Stu_c said:no it wont just do a small section because its a whole brake kit so it will be designed for the size of the disc.
http://k-tecracing.com/show_product.asp?id=873
You'd need new brackets making for if you buy a 172 etc though so no point buying for later.Stu_c said:look good tho plus i will do an engine conversion later so might as well buy it now rather than buying it for this engine then buyin it again later for better stuff
