Fitting brake pads?
  Liquid Yellow 182 FF
Quick question,
My front break pads on my 1.2 16v Clio have almost gone, and I don't fancy paying a garage near on £100 to do it as I know the parts arn't very expensive. How easy are they do fit yourself? I don't have the most amazing technical knowledge but is it possible? Any guides or links?
Mark
  Clio182
Take wheels off undo calliper from carrier pads will come out quit easy undo resiour cap use clamp to push piston back copper grease back off new pads install wheels back on pump brake pedal all done.
DrR
  VW Golf GTD
brake not break
It's easy, take the wheel off and look at the pads/caliper, if it's not obvious what you need to do, go to a garage.
Or buy a haynes manual.
brake not break
oops, SP. I shall have a flick through my Haynes manual when my mate gives it back. I will have a gander.
Matt W
  Volvo XC60 T8
There is a guide in the guides section :)
LOL!
TheEvilGiraffe
brake not break
Well, it is French..... the first was reasonably appropriate.
Easy job to do yourself. Find a friend who is mechanically competent to help you first time round tho as you don't sound too confident. Just remember, if you've driven anywhere, the discs and pads will be WARRRRRM.
Use a torque wrench on wheel bolts (when putting it back together ;) ).
Also don't use the Renault jack. You're safer drinking brake fluid TBH.
Don't drink brake fluid.
TheEvilGiraffe;7433955]Well, it is French..... the first was reasonably appropriate.
Thank you, It doesn't sound to hard, but I will get a friend to give me hand. Common sense then. Im going to have a little look anyways tomorrow when I take my wheels of to sort my camber.
