fitting engine mounts
Car  Monaco 172
ive just ordered the upper and lower gearbox mounts, can anyone give me a rough guide as to how to change them?
cheers
Are you getting play from the ones that are on it the now?
What kind of noise does it make? I think i have the same problem?
when you let off the accelerator it makes a clunk noise and its getting increasingly more difficult to change gear at times. ive teen told both are mount related. know how to fit them?
Pete, did you try tightening the mounts? I had the same problem and just tightened the bolts. It's all ok now! As for fitting, it isn't that hard, jus need to make sure u support the gear box! I'll fit them for you if you need?
well the gear box one below is all stretched out and what not! but if you can tell by looking at them thats not problem. im sure i can fit them its just knowing where to start really! where is whiterock? cheers
ah right, theres a few whiterocks i think! handy enough if its down comber road! ill see when they arrive then!
cheers
Hmm i believe this is exactly the problem i have, i may change them all just to be safe ( im very picky on things like this).
Big job?!?
