Fitting ITG maxogen
Car  172, Westfield
In the instructions it says to remove/disconnect a vacuum control solenoid!
Is this what people call the accoustic valve!
Do you have to do this!
Do you remove all old air feeds as I thought the kit hoooked up to one of the old feeds?
If not does it just point down to the corner or do you need some extra ducting?
Dude I aint got the instructions anymore! lol From memory you need to remove the accoustic valve and there should be a thin pipe that leads from that to the top of the inlet mainfold... which you need to plug up.
Give me a ring tomorrow am if you are still stuck.
Rip everything out. Fit Maxogen which takes about 2mins! Bolt under the slam pannel....
JOb done. I didn't run a feed on mine. No real need imo! - Good choice on kit.
