Fitting Xenons?
Car  RB 197 Cup
I have a 2003 dynamique and i am considering fitting some xenons. are they easy to fit and is there anything i need to get to fit them?
cheers
are you talking about 172/182 headlamps??
theres someone on here who has fited them to a basemodel. cant remember their name though.
172/182 headlight units still look slightly better though.
Pretty expensive, and time consuming doing it with renault parts though
well i just wanted to know if i just need to get the headlamps and if its just a straight swap or whether i needed to get any other parts to make them fit and work. i dunno if i will do it i was just wondering if its an easy job or not.
to fit the complete kit, i think you'd have to run the wiring for them, fit the adjuster on the rear axle, and headlight units, and ballast pack(s)
easier and cheaper going for the aftermarket addon.
^^^ No the auto adjustment is made from the rear axle as mentioned.
The lamp only consists of the charge packs.
Hence when u retro fit them they stay at one level which piss people off when u go up or down hill!
ta da!
