Freeing seized coilovers
leeds_182
North Yorkshire & Humber
While I was having my itbs done I asked the guy doing it to wind the front of my car down a little - spax coilies fitted.
unfortunately, the fronts were seized and despite soaking them in penetrating fluid they still wouldn't budge?
Anyone any suggestions or shall I just get used to my ride height...
JezzaMac
Wire brush the threads and get them as clean as possible. Give the C spanner a dunt with a hammer to try and shock the lock ring free. Also might be worth taking the units off and pouring a big bottle of coke over the adjuster, I read somewhere that sometimes helps! lol
Just a couple of suggestions but i'm sure someone will be along with better ideas!
  Clio 172 phase 1
Body shop degreaser soak them with it or carb/brake cleaner and let it soak in
buy it as a fluid not an aerosol it'll be dirt and s**t stuck in the threads a small pump sprayer and a good trade degreaser worked well on my mates .... Other than that oxyacetylene torch and heat up the adjuster slightly?
  GTD, Lupo
I had an old set that I left in a tub full of coke! Left them for 12 hours in about 10ltrs of the stuff! As good as new after! Just don't drink the coke after!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I find a flat ended drive and a lump hammer usually works after a few squirts of penetrating fluid.
  GTD, Lupo
To keep costs down on the coke go to icelands and by the 3ltr bottles for £1.50. Don't buy cheap! But it did unstick mine and I had tried almost everything!
