Front Bumper Strips Removal
Car  Clio 1.2 16v
Hi Fellas,
Just wondering if there is any hints and tips on removing the three plastic strips on the front bumper of a Dynamique. Or do I literally have to take the whole front bumper off to remove them?
Ive got colour coded ones to replace them now! :cool:
Apologies if this has been posted before.
Footerz
take the whole front bumber off... 2 plastic clips underneath the front 2 corners plus 2 torx screws just next to them..
followed by 2 torx screws half way up both of the front arches then 2 10mm bolts once you pull back the arch lining...
p.s dont forget about removing the grill before attempting to pull your bumper off..
once you have it off there is clips all the way along the inside of the bumper to remove the bump strip.. can be easily removed with a flat head screwdriver on each tab..
hope that helped
i took mine off without removing the front bumper.
find an old butter knife or similar in the garage. then slide it into the recess and you'll feel the triangular wedge clip things. diffiuclt to describe but if you put the knife in and then flick it downwards they should just pop out.
is this the same for the rear middo ??
cheers
