Front Tweeters
  Audi TT 3.2 V6
just wondering is it possible to pop the current tweeter grills of or is it a must that i have to remove the hole top of the dash?
wana replace my current tweeters with my infinity comps at somepoint, prob will have the tweeters in the current tweeter position but will loose the oem tweeter grill and position the tweeters pointing towards the driver + passenger. not to sure on pulling the top of the dash of...sounds a fair size job.
any suggestions welcome
  Clio 172mk2
yep just found out today twist clock wise 45degrees roughly then they pull out and then the tweater itself unclips
they do twist out, but again, they're not supposed to
however, by using the existing speaker cable, you'll end up with a full-range signal coming from the speakers therefore causing a degree of damage
get your dash off and get some proper speaker cable in there
