fuel pipe split. front left hand corner of engine bay- 172..
  330i. E30 Touring.
The pipe at the front left of the engine bay that goes into the fuel rail? Has a split where it joins. Anyone know the part code? Where does it go at the other end? I'll upload pics later if anyone needs..
  330i. E30 Touring.
Does anyone know of a glue that is not melted by petrol, and that will stick plastic and rubber together..
  Lionel Richie
front left if you're standing looking at the engine i assume??
is it pissing fuel out of the join between the fuel line/rail?
M
mini-valver
If its split along the pipe, cut it and join it with a connector from the washer tubing.
  330i. E30 Touring.
There's a joint between the skinnier plastic pipe which goes towards the back of the car and the chunkier rubber pipe which joins onto the fuel rail. It's pissing out of the join when under pressure. I've taken it off, and re glued it on, but it's done it again..
  172 cup
just to drag this one up, I need the o ring that goes on the connector which seals it onto the rail, anyone know a size or where to get one
