Fuel pump doesn't work.
Car  Clio 172 RS ph1
Hi there,
I had and 'alarm code' car security system, I took it off and put back the original car wiring, near the driver they cut off the fuel pump + wire and connected it to an external relay, I fixed the original wire to the original connector, but now the fuel pump dosent work, but if I give it 12v directly it works perfect.
What could it be? Does the pump has a relay/fuse?
or if some one has the full wiring diagram, to see how the wiring is going from the fuel pump to the fuse/relay.
Still trying to find some answer over the internet, how the fuel pump gets the 12v?
Whats the order? Switch-relay/ fuse-ecu-fuel pump? Until now i connected the fuel pump to an +12v after switch from 1 of the fuses, but the problem is that on switch the fuel dosent stop after building the preasure.
Any ideas?
