2.2's for a road milage car.........not such a great idea. Bores become thin, cylinder sealing area becomes tiny (prepare for blown head gaskets if its not built perfectly). Plus the 84mm pistons on the market are plain crap and not something i would be running on a daily basis. Infact, none of the forged pistons on the market are that impressive, and most are pure junk, certainly wouldnt be wasting my £500 on the crap thats out there.
I would stick 2ltr, stock crank, forged pistons and rods.........a steel crank is just a total waste of money as you wont make the torque to break one, nor reach the rpm to break one with the stock RPRF valve actuation. Hell.............you wont even really need steel rods without good purpose.
And as far as i know, from the pictures, andy is running a stock crank.........cant see any logical reason to run a steel one.
And on a side note, our AWT pistons will be out in the new year. I've pushed the manufacturer to spend the dosh making a new forging die specific for the piston design i require making it ultra light and ultra strong. It'll be made out of far superior alloys, with superior rings and a piston taper that will allow 8 tenths of a thou clearance when running (hot) without issues.......which means zero piston rattle from cold. And even better........they will be cheaper than the best offerings out there at the moment, there will be no reason for anybody to buy anything else.
Is a rebuild even needed if its in good nick?
