172MKII 10K on the clock not probs. lots of rattles over bumps.. but with the eibachs the suspension is @ the point of very firm, not quite backbreaking but enough to unsettle a cheap cars dash..
BTW although the 172/182 arent very cheap they can be found brand new from importers for very little. compare that to a ford focus new and youl see that all the cost on the focus, has goine into interior build, safety. and the clio is still interior wise a 1.2 pretty much.
Firstly, I am NOT writing an article of the 182 (Be serious, mate). I wrote my article with my old 172 Mk I when I had a row with R and got behind the scenes just enough to see all the f....y happening.
Secondly, next week I am putting my deposit down and I just needed to hear some comments from your point of view.
Thirdly, I would like to tell ya the following. There is simple equation: No honest criticism + no honest feedback from users = No progress, that is, no development.
I did whola lotta things to remind R that they should redesign the exhaust system. AND THEY DID - ON 182 !!!!
6. Gearchange lever smoothness. Have you experienced any troubles when changing from the upper to the lower gear? If Yes, what was the sequence? 5th->4th or 3rd->2nd?
ive got a 172 cup, and i have the occasional problem going down from 5th to 4th
Considering the tech facts that
- new “3Y” exhaust manifold (which replaces the former
“4-into-1”) should improve a gas outflow and allow better cylinder filling,
- greater duct length of this new manifold should result in higher torque in all speeds,
- more compact metallic (1st appearance in the R range) catalyst should provide less resistance to thru-flow and finally
- two parallel-mounted silencers should achieve proper reduction of the back-pressure,
I believe the Clio 182 exhaust should represent a real improvement. But we shall see how it functions in real "road hawg" conditions.
