Grooved discs - wet braking issues
TheEvilGiraffe
Coming along the motorway the other evening, in heavy rain, waterlogged (not quite aquaplaning levels) doing about 50/60ish, and I had to brake as the traffic was queueing on the slip road ahead. Press middle pedal .. nothing .. press harder .. starts to slow a bit .. press harder, change underwear, and eventually it slowed a bit but the noises and lack of braking efficiency scared me a little to say the least !! :dead:
Once the pads were a little warmer, the second (I was prepared this time!) attempt was a little better but not much. Once I got off the m'way and it wasn't waterlogged, the brakes were ok !
It's happened a few times in the wet, but not to that extent before. The pads have plenty of life left, the discs all seem ok, but they are grooved. I'm wondering if water sits in the grooves or something ridiculous, and stops the surfaces touching properly !? In the dry, after one stop, the brakes will pop eyeballs from sockets. So I'm properly confused and slightly concerned !!
Has anyone experienced this before ?! :S
Gaz_
  Extreme mode
I've got some ebay specials on mine i think (on the car when i bought it). Find them poop when wet and cold, but fine once used a few times. Pads are some cheapo mintex jobbies
TheEvilGiraffe
Renault Clio (B) (98->) 2.0 16v Sport 172 99-04
Tarox G88 Brake Discs (Front)
WAS £193.20NOW £173.88 (inc VAT) per pair
:headno:
They better be bloody good haha. Cheaper than 4-pots I spose :)
Best pads to go with....? Fast road .. no track stuff needed.
TimR26
South Central- West Berks
That's not too bad a price, my mate works for a motor factors so I only paid £105+vat. I'm running DS2500 with mine.
  Iceberg Ph1
The ones I got dude are spot on tbh... Tested them out about 10mins ago with some sideway roundabout action which required some hefty brake work to control! Dam the Clio and its lively rear end!
Read so many raved reports on the DS2500 Sets on KTec.. Could be worth giving them a try?
Edit: I'm on about the Brembo HC And DS2500 Sets btw!
TheEvilGiraffe
Your shocks are defo f**ked. :nono:
But back on topic.. what did you get in the end !? I know I was there at the fitting :eek: but I was mildly hungover and I've been asleep since then...
  Iceberg Ph1
I blame the tires lol, I have brand new shocks remember :rasp:
Got mine off the Bay.. I will search for a link..
