Guide to fitting Upper Engine Mount?
Take of engine cover.
Loosen top bolt.
Loosen 4 big bolts.
Jack up engine (gently).
Swap over.
You might need to loosen the upper gearbox mount, as mine was off when I changed it over.
Reverse to fit.
Use a trolley jack under the engine and make sure it grips the sump well. If it slips off the jack you'll need engine bay repairs that are really really going to cost.
Also while your taking off the engine mount be sure to take off that heavy lump of iron on the side.
Just as easy with the dogbone. Make sure the engine's supported and it's a doddle.
