Guide to fitting Upper Engine Mount?
  330i. E30 Touring.
Take of engine cover.
Loosen top bolt.
Loosen 4 big bolts.
Jack up engine (gently).
Swap over.
You might need to loosen the upper gearbox mount, as mine was off when I changed it over.
Reverse to fit.
  ValverInBits
Use a trolley jack under the engine and make sure it grips the sump well. If it slips off the jack you'll need engine bay repairs that are really really going to cost.
  Evo 6, E92 320d
Also while your taking off the engine mount be sure to take off that heavy lump of iron on the side.
  330i. E30 Touring.
Just as easy with the dogbone. Make sure the engine's supported and it's a doddle.
