I'm after some reviews/feedback from anyone who's got H and R coilovers on a 182 cup. How do you find them on track? I've heard they're good on roads but need feedback before I commit to adjustable coilovers.
After a few weeks of driving my 182 after having H+Rs on my 172 for about 8 months I can say the coilovers improve the ride. Stopping bump steer, but the standard suspension is more enjoyable and its free!
I think standard set up is fine once you get some negative camber at the front, but my rear shocks are on their way out as it gets a bit "floaty" on track.
My only concern is the H and R's wont be firm enough for track work.
I think they are excellant, better composed than the standard stuff and not too stiff. Has created a bit of torque steer on really ruff roads, but that is to be expected.
As has been said, if you let us know where you are there is probably somebody around that would give you a ride out in there car.
Bit soft at the rear for dedicated track work, but depends how committed you are to driving an uber stiff car around on the roads on a daily basis. Otherwise superb.
Thanks for the response, don't mind a hard set up within reason, it's just I find at present mines a bit wallowy under heavy braking, (Eibach springs, -2 negative camber). As said before don't want to get H & R's and then regret it because I feel the back end is trying to overtake the front under heavy braking. Hope this makes sense. Are the springs progressive ?
better off getting a kit that is fully adjustable, height/damping/camber, if you are doing a lot of trackdays, no point going halfway then regretting an expensive purchase.
I know what your saying but H & R's or KW v2,( possible to mod 172 dampers) are £700-£800 and 2/3 way adjustable £1200 - £1500 plus fitting and setting up. With the extra £500-£700 could go on other mods.
H and R which arn't adjustable are fine for most user for track and road use if you can and will know how tyo use the adjustables then get them though.
