H&R coilovers
well they being sold by mr fmp off here and he has a 182cup, so yeah you'll be fine as long as you have cup packs
iirc, the 182 cup or non cup have the same fitment.. or so i was told..
but 172 ones wont fit... so these should be fine
Mr Fmp you say! Might drop him a PM then :)
Pretty sure my car has the cup packs! lol! I have the splitter, did have the 182 anthracite wheels as well!
Justin are you saying these will not fit a cup packed 182 then?
Daz
when i got mine, i was told there is a set for all 182's, and another set for all 172's.. cups, or non cups..
so yeah these should fit mate
that wasnt all that clear either i dont think.. if your car is a 182, you buy a 182 set.. if its a 172, you buy a 172 set..
whether u have a 172 cup/FF or 182 cup/FF i dont think it matters
:cool:
Just don't want to possibly spend that much money and them be the wrong ones :D
So as long as I am buying a 182 set I should be fine then, now I am confused
yeah i know.. the guy on here isnt actually called mr fmp, but i cant remember his username, im sure someone will know.. :)
182's with cup packs, and 182's without have different fitments to each other guys... But as far as im aware, matt had a cup packed 182, so these should fit yours daz.
Aye, bit confusing mate, but been told it this way round by a few people. Think its what fred meant in post above by checking if his had the cup packs or not.
Check rory's thread on the difficulty he's had in getting dampers to fit his non packed 182...
http://www.cliosport.net/forum/showthread.php?t=209244
All 172's on the other hand, be they ph1, cup, or ff ph2 share the same damper fitment.
yeah, well when i ordered mine, i was asked if it was a 182 or 172, i said 182, then i said it was a cup, and the guy said it doesnt matter, as the 182 kit will fit all 182s
have a look on 2modified.com
Doesnt really affect me as i have a 172.
Might be best for daz to ask fmp himself, to be on the safe side.
Theres two different hubs
54mm as fitted to all 172's and all non Cuped 182 (trophys also have these I belive) the none cuped 182 since have a wider track due to different wishbones and shafts means that to make 172 stuff fit them they need to be angled more so either camber correction bolts or slotted holes
60mm hubs as fitted to the 182 cup packed cars
aye non cup 182 is different, it's a hybrid of 172 hub with wider 182 track so you'd need camber bolts and possibly slotted top bolt holes and camber bolts to give you the correct camber using 172 parts.
^ oops edde beat me to it.
For any non cup 182 owners out there Koni are developing their adjustable shocks for us!
